How to Set Up AutoCAD for 3D Drawings
If you’re new to the AutoCAD 3D game and you’ve been working in 2D until now, you need to do a couple of things before you can start a new 3D model in AutoCAD: You have to change the workspace, and then you have to open a new file by using a 3D template. The following steps explain how:
1. Open the Workspaces drop-down list on the Quick Access toolbar, or click the Workspace Switching button on the status bar and then choose 3D Modeling.
Toolbars, palettes, and Ribbon panels flash on and off, and soon AutoCAD settles down to display the Ribbon, as configured for the 3D Modeling workspace with a few additional panels.
2. Click the Application button and choose New; then click Drawing.
    The Select Template dialog box appears.
3. Choose acad3d.dwt if you’re working in imperial units or acadiso3d.dwt if you’re working in metric. Click Open.
    A 3D modeling space appears where, rather than look straight down at the drawing area, you look at it at an angle from above.
leowarren34
This is ideas not the forum, did you post in the wrong forum?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
