AutoCAD Forum
layout viewport & xref
7 REPLIES 7
Message 1 of 8
alaahashem
2571 Views, 7 Replies
hi every one , I have a problem
I have master plan and I want to create 2 drawing from it
but I want to show some entities in drawing and another in second drawings
I freeze view port layer but when I make any new work in master plan and update the 2 drawings I found all entities have been show
how can I solve that
any one can help me
7 REPLIES 7
Message 2 of 8
imadHabash
in reply to: alaahashem
from your Viewport itself click inside it , then type Layer command . from the dialog that appear go to the VP Freeze column and start freeze the unwanted layers . any changes ?
Imad Habash
Message 3 of 8
alaahashem
in reply to: imadHabash
thanks for your help
I do that but when I do any change at xref which I take view port from it
and the drawings update and the layer which I freeze go back to be UN freeze automatic
Message 4 of 8
imadHabash
is there any Layer Filters that you use ?
Imad Habash
Message 5 of 8
alaahashem
no
 I don`t use it
Message 6 of 8
imadHabash
Ok ... check your VISRETAIN (System Variable) . >> Click <<
Imad Habash
Message 7 of 8
alaahashem
Thanks alot for your help
yes it solved by
VISRETAINMODE ===> (2)
https://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-46480687-6DFF-499E-B7C0-E741AEA11D00&_ga=2.53...
Message 8 of 8
imadHabash
Glad to hear that ... Smiley Happy
Imad Habash
AutoCAD Inside the Factory
