hi every one , I have a problem
I have master plan and I want to create 2 drawing from it
but I want to show some entities in drawing and another in second drawings
I freeze view port layer but when I make any new work in master plan and update the 2 drawings I found all entities have been show
how can I solve that
any one can help me
Solved by imadHabash. Go to Solution.
from your Viewport itself click inside it , then type Layer command . from the dialog that appear go to the VP Freeze column and start freeze the unwanted layers . any changes ?
Imad Habash
thanks for your help
I do that but when I do any change at xref which I take view port from it
and the drawings update and the layer which I freeze go back to be UN freeze automatic
Thanks alot for your help
yes it solved by
VISRETAINMODE ===> (2)
https://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-46480687-6DFF-499E-B7C0-E741AEA11D00&_ga=2.53...
