Layer Showing Inaccuratley
EGambonNPV8G
EGambonNPV8G
Community Visitor
Community Visitor
I have a sketch on one layer and the layer properties confirm this. If I turn that layer off the sketch stays. If I turn off the original layer I copied the sketch from it turns off. This doesn't make sense.
CGBenner
@EGambonNPV8G
Welcome to the forums!  Is it possible to share a drawing file where you see this behavior, for the experts to look at?
Chris Benner
Kent1Cooper
What you are calling a "sketch" is a Block Reference [or Insertion].  If the pieces in the Block are drawn on a different Layer than the one the Block is Inserted on, but not on Layer "0", then they will show even though the Block's Layer is turned off.  But if you Freeze that Layer instead of [or in addition to] turning it Off, those nested objects will disappear.
Kent Cooper, AIA
imadHabash
Since you're treat with a block then it's normal by turning OFF that layer (.working). Only items exist on layer 0 (zero) inside the block will turning off. BUT if you freeze that layer (.working) then you will get the expected result.
Imad Habash
CGBenner
@EGambonNPV8G
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
