Layer not correctly retained when adding block to existing tool palette
Hi
I'm delivering a course at a client's premises and have been showing the delegates how to create a block on layer zero then add them to an existing tool palette by clicking and dragging the block to the palette.
We are experiencing a problem - when the block is then placed from the tool palette, the colour of the block is displaying the colour of layer zero and not the colour of the layer we are attempting to place it on.
I'm not sure this error has happened on other courses I have delivered. I don't recall seeing it before.
The client is using AutoCAD 2015.
Any help on this issue would be gladly accepted.
Many thanks
Wendy
Moshe-A
Wendy Hi,
click on the that tool and go to properties under general verify that the color is set to bylayer (not byblock?)
also verify that the current drawing color is bylayer.
Moshe
Hi Moshe
we have checked and the colour in the properties is set to ByLayer as it should be. None of the delegates have changed this setting.
Also the current drawing colour is set to ByLayer.
Many thanks for your help
Wendy
pendean
Community Legend
Community Legend
The block is still on layer 0?
Show us, post a DWG file with the problem, let's all look under the hood.
Ranjit_Singh
After adding the block to palette, change it's properties under layer  to --use current
Many thanks Ranjit, Moshe and everyone who responded.
You're all stars! I'll use the solution that Ranjit offered, as a general way of making sure my delegates get the correct layer when placing blocks.
Thanks all again
Wendy
