Just want to move object from DEFPOINT layer to visible layer for plotting, Need full AutoCAD?
texas_ed
texas_ed
Community Visitor
Community Visitor
I'm trying to convert some 20 year old .dwg files to PDF, and some content isn't rendering. Looks like some of the content shown in Layout1 is actually on the DEFPOINTS layers. This is 100% a mistake, it's the drawing title block. Other .dwgs in the same set are plotting the same title block just fine.
My question is, do I need to install the full-blown AutoCAD set just to move some objects from one layer to another? Is there a simpler/cheaper way to do it?
RobDraw
All that you need is a program that can edit .dwg files. There are many and come in different flavors. Some may suit your needs, others, not so much.
Share a file and you might get a more direct answer.
Rob
vinodkl
Hello @texas_ed
You can download the trial version of the AutoCAD and do it for yourself or upload the drawing so that we can help you out 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
paullimapa
Since you need to move objects from one layer to another, then free dwg viewers which only allow you to view and plot does not give you the option to modify. You’ll have to install at least AutoCAD LT or some other compatible dwg editor to perform this operation.
Paul Li
IT Specialist
@The Office
