AutoCAD Forum
Join/Combine Regions
7 REPLIES 7
Message 1 of 8
ahmedshawkey95
1614 Views, 7 Replies
How can I join multiple regions (not intersected regions) to create only one region representing them as shown below?
Input regions:
Required output as one region:
I tried to use the following boolean operation commands but didn't the required output.
Ahmed
Labels (1)
7 REPLIES 7
Message 2 of 8
Patchy
in reply to: ahmedshawkey95
Group, or block them.
Message 3 of 8
No "following boolean operation commands" included.
How did you make the "required Output" portion of the drawing?
Kent Cooper, AIA
Message 4 of 8
ahmedshawkey95
in reply to: Patchy
I need them to be represented as one regio entity. Other types aren't allowed.
Message 5 of 8
It was a hatch and converted to a region using this Autolisp but I want to know how to do this using native AutoCAD commands.
Message 6 of 8
Hello @ahmedshawkey95
Your explanation is not clear. If I understand you correctly, (and I might not be) then you can use REGION and SUBTRACT commands.
Try this:
  1. On command line=>REGION=>select all objects (1 large rectangle, 2 small rectangles and 3 circles). This will result in 6 individual regions. See image-1.
  2. Without any objects selected, go to command line=>SUBTRACT=>select the large rectangle (rectangle will turn into a dashed line when selected)=>ENTER See image-2.
  3. The command line will now wait for you to select object(s) you wish to SUBTRACT. Select 3 circles and 2 small rectangles=>ENTER. See image-3.
  4. A single region has now been created. See image-4.
  5. Hatch the NEW region and it will look like this. See image-5.
Image-1Image-1
Image-2Image-2
Image-3Image-3
Image-4Image-4
Image-5Image-5
Chicagolooper
Message 7 of 8
@ChicagoLooper Thanks so much. That's exactly what I was asking about.
Message 8 of 8
@ahmedshawkey95
You're welcome.
BTW, you can also use a REGION to create a viewport. Using the same operation explained in the earlier post, draw the regions directly on a layout tab so they're in paperspace, not modelspace. Then use the OBJECT option to convert the region into a viewport.
Modelspace containing objects.
1-Objects in modelspace look like this.1-Objects in modelspace look like this.
While on a Layout Tab=>Layout Tab=>Layout Viewports Panel=>Object from the dropdown=>Select the Region.
2-The region is considered an OBJECT and this object can be used as a viewport.this2-The region is considered an OBJECT and this object can be used as a viewport.this
Chicagolooper
Forma Design Contest
