How can I join multiple regions (not intersected regions) to create only one region representing them as shown below?
Input regions:
Required output as one region:
I tried to use the following boolean operation commands but didn't the required output.
Ahmed
Solved by ChicagoLooper. Go to Solution.
No "following boolean operation commands" included.
How did you make the "required Output" portion of the drawing?
It was a hatch and converted to a region using this Autolisp but I want to know how to do this using native AutoCAD commands.
Hello @ahmedshawkey95
Your explanation is not clear. If I understand you correctly, (and I might not be) then you can use REGION and SUBTRACT commands.
Try this:
Chicagolooper
You're welcome.
BTW, you can also use a REGION to create a viewport. Using the same operation explained in the earlier post, draw the regions directly on a layout tab so they're in paperspace, not modelspace. Then use the OBJECT option to convert the region into a viewport.
Modelspace containing objects.
While on a Layout Tab=>Layout Tab=>Layout Viewports Panel=>Object from the dropdown=>Select the Region.
Chicagolooper
