Jerky Cursor in AutoCAD 2018
Message 1 of 142
I've just started AutoCAD 2018 version.
I have everything working fine EXCEPT for a jerky cursor.
It works smoothly until a command is started.
Then, it takes a full second before it moves and then it jerks, almost as if a snap was set.
I've check past postings and have adjusted as suggested, but, to no avail.
I'm ready to start over and follow any suggestions you all out there might have.
Read Ya Later -KLYPH
@Anonymous,
john.vellek has edited your subject line for clarity: Jerky Cursor
Replies (141)
Message 121 of 142
matt
Thanks but it could take me 2 years to find "Wireframe". Autocat has thousands of commands and routines.  Thjousands. So this is no help unless someone is already familiar with wireframe.
Thanks anyway.
Message 122 of 142
JamesMaeding
@matt
This thread was not about snap. That is within the realm of autocad features put there on purpose.
This is about the cursor lagging when a command is started.
These are experienced people posting on the real issue and we are getting people posting on snap...
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 123 of 142
YES YES YES. Worked for me
SNAPMODE to 0
Message 124 of 142
Nice one. Yours should be marked as solution too. Worked for me. Thanks
Message 125 of 142
I have turned OFF the Snap cursor to 2D reference points(F3). Thanks it's works.
If anybody still having problem try below steps.
Turn OFF snap mode(F9).
Turn OFF Snap cursor to 2D reference points(F3).
also toggle between graphics acceleration from GRAPHICSCONFIG command.
Message 126 of 142
Type 3DCONFIG and turn it off. it will work.
Message 127 of 142
mail
@JamesMaeding
We figured out the mystery on our side.
The symptoms revolved around Selection Cycling - when Selection Cycling was set to 2/ON, jerky cursor, when set to -2/OFF, no problems.  Removing the problematic XREFs temporarily fixed it, much like what you guys were dealing with.  This problem was happening on multiple machines with different configurations.
The problem was specific to a particular CAD file.
A suggestion by someone in this thread pointed to FONTS being used in the CAD file causing issues, and I think I may have found the culprit.
The particular project we're using uses Futura BT TRUETYPE fonts.  We were supplied these fonts by the architect for their border as a standard, but the architect ALSO used these fonts on their *room names*.  The other poster said it was their Swiss family of fonts, which is ALSO a truetype font.  (TTF files)
We noticed the slowdown happens when our mouse hovers over room names with that Truetype font being used.  If we use built-in AutoCAD fixed width fonts like Romans we have no problems, so therefore as a solution to this issue, we simply reformatted all the room names and fonts to use Romans - it looks uglier, but the architect never said anything about using their font standard for their backgrounds.
This was happening on three different computer configurations.  One was an i7 6700k running Windows 10 and AutoCAD 2019, another with an i7-4700k running Windows 8 and AutoCAD 2018, and another on a Xeon E3-1270 running Windows 7 and AutoCAD 2014.  All these programs can reproduce this problem by simply turning selectioncycling on/set to 2, so it's been a longtime issue, it's not new to 2017.  Hate to necro an old post but I came from Google searching.  The slowdown only happens if the cursor hovers over the text.
Message 128 of 142
The solution that worked for me was:
Go to settings, Dynamic Input and disable all dynamic input settings (disable 'Enable Pointer Input','Enable dimension input',' and both 'dynamic prompts')
and
Go to options/drafting and disable 'display autosnap tooltip' and disable 'display autotrack tooltip'
The jerky or sticky tooltip is now mostly gone for me.  I use 2016 on this machine with dual nvidia GTX 980's.
It's been so frustrating having poor cad performance with top dollar gaming hardware.
Message 129 of 142
{Daniel}
On C3D 2020
disabling selection cycling made a huge difference! (ctrl+W is the shortcut)
Thanks a lot!
Message 130 of 142
Tommy2shoes
I need to use the perpendicular snap often, so it is usually checked on my list of snaps. It has been a problem though since for some reason it becomes a preference  for the program over the basic ends and middles. Many ends & intersection snaps I've missed over the years because of this, even though it is not noticeable on a print.  I would recommend keeping it off and type in "per" when you actually need it.
Message 131 of 142
pendean
Community Legend
Community Legend
Some osnaps should not be "running" all the time, this is one of them (so is NEArest).
Thanks for sharing.
Message 132 of 142
beyoungjr
In addition to Dean's remarks, I would also remind you that you can also use [shift+right-click] while in the command to get the list of osnap overrides and choose the one you wish to use.  It's same result as typing "per" or any other alias for an osnap override.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 133 of 142
JamesMaeding
How in the world did this thread descend into "try turning osnaps off"?
Please people, read the threads a bit more. Try looking at the first couple posts.
This is not about acad basics. The people with the real jerky cursor problem have years of experience, many have more than the people at autodesk trying to help us. Just read the threads please.
Message 134 of 142
vikingranchhq
Community Visitor
Community Visitor
Resurrecting an old thread, this turned out to be the solution to my maddening cursor issues in 2022LT. Still not clear what it did, but I'm not losing my mind anymore.
Message 135 of 142
JamesMaeding
@vikingranchhq
If you are on LT a jerky cursor is the least of your issues.
Why not buy Bricscad Pro for same price as LT and get full acad abilities?
It has civil3d object enablers in case you are worried about that.
It does full lisp and .net, menus...all the stuff LT is missing from full acad, for same price.
thx
Message 136 of 142
RobDraw
@JamesMaeding wrote:
@vikingranchhq
Where have you been? I see that your Autodesk bashing skills haven't gotten any better.
Rob
Message 137 of 142
JamesMaeding
@RobDraw
You should try Bricscad too.
Message 138 of 142
RobDraw
You're assuming that I haven't.
Rob
Message 139 of 142
JamesMaeding
@RobDraw
Oh, sorry, I thought you were a microstation guy.
Message 140 of 142
pendean
Community Legend
Community Legend
@RobDraw
I've been seen there sometimes 😉
