Issue using Dimedit Command for isometric in AutoCAD 2016
Message 1 of 8
Dear Support Team,
I need dimension oblique for my isometric drawing. When I enter command for dimension edit. It asks me to select option, I select "Oblique" option. It should ask me to enter angle, but it asks me to select object.
What is the issue and solution.
Please review the attached snapshot.
Majid Razzak
0092 304 2275 456
Accepted solutions (3)
Replies (7)
Message 2 of 8
S.Faris
You need to select the dimension, then press enter, to get the promt for providing angle.
Command: DIMEDIT
Enter type of dimension editing [Home/New/Rotate/Oblique] <Home>: O
Select objects: 1 found
Select objects:(enter)
Enter obliquing angle (press ENTER for none): 60
SALMANUL FARIS
Message 3 of 8
Thanks for your reply.
I follows the same steps as you told. But when it asks to select object, then I select the object. But the object has not been selected. It shows, 0 object have been selected.
Message 4 of 8
S.Faris
You need to select the dimension, which you need to do in advance.
SALMANUL FARIS
Message 5 of 8
Ok. I understand. You mean that I should draw dimensions first. Then select them.
Thank you
Majid
Message 6 of 8
S.Faris
Yes exactly. The command is DIMEDIT is to edit an existing dimension.
SALMANUL FARIS
Message 7 of 8
224001167
Community Visitor
Community Visitor
IM DOING THAT BUT IY STIL SAYS 0 OBJECTS FOUND
Message 8 of 8
cadffm
Layer locked?
Not a dimension object?
Share your sample .dwg and mark the dimension in question.
Or cooy the file and delete all, except one dim
Sebastian
