AutoCAD Forum
Is there a way to join multiple splines using a single command?
5 REPLIES 5
2025 Views, 5 Replies
I want to join multiple splines using 'blend' or 'fillet' as the picture below.
Is there an easier way than click a line one by one?
Please, see the attached image that explains my question.
5 REPLIES 5
Alfred.NESWADBA
how should any of these commands know (automatically) which splines should be connected?
I would now know any automatism to do this not manually, as for command _BLEND it is also important for the command to know which ends of the splines should be connected (...well, a self written tool may solve your specific case).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
ВeekeeCZ
See THIS similar thread -- my post with the routine and screencast. The routine uses the BLEND command, but there is a link down below post with a FILLET version.
In case you don't know how to use a LISP, see THIS manual.
(I was confused, I've thought you both are the same guy, so I've posted the routine there, but it was intended as solution for your example. Now I see different nicknames)
in reply to: ВeekeeCZ
Is there no BLEND version?
Is it possible to make a BLEND version by modifying a FILLET version?
ВeekeeCZ
There are both versions, see my link carrefully.
Thank you very much!
That's what I was looking for!
Forma Design Contest
