I want to join multiple splines using 'blend' or 'fillet' as the picture below.
Is there an easier way than click a line one by one?
Please, see the attached image that explains my question.
Solved by ВeekeeCZ. Go to Solution.
how should any of these commands know (automatically) which splines should be connected?
I would now know any automatism to do this not manually, as for command _BLEND it is also important for the command to know which ends of the splines should be connected (...well, a self written tool may solve your specific case).
- alfred -
See THIS similar thread -- my post with the routine and screencast. The routine uses the BLEND command, but there is a link down below post with a FILLET version.
In case you don't know how to use a LISP, see THIS manual.
(I was confused, I've thought you both are the same guy, so I've posted the routine there, but it was intended as solution for your example. Now I see different nicknames)
