AutoCAD Forum
Is there a way to edit a topography in AutoCad?
2 REPLIES 2
377 Views, 2 Replies
I'm trying to edit a very irregular topography that I imported from Sketchup but I can't modify the levels to draw above it like I need to, any advice?
Labels (1)
2 REPLIES 2
TerryDotson
It looks like (from the picture) that you have a 3dSolid or 3dMesh of a surface (with a flat base and skirt).  You might be able to explode it to work with the surface triangles only.  What do you want to see, contours, cross sections?
tboehler
This looks like a Civil 3D model - a 3d view of the TIN lines.  Probably good contours in there if you have Civil 3D.  You can attached the file for us to verify.
Forma Design Contest
