The currently newest AutoCAD version 2022 can be read with AutoCAD 2018 and newer (they use the same file format).
For future AutoCAD versions we don't yet know it.
AutoCAD 2013 can read up to AutoCAD 2017
AutoCAD 2010 can read up to AutoCAD 2012
AutoCAD 2007 can read up to AutoCAD 2009
AutoCAD 2004 can read up to AutoCAD 2006
AutoCAD 2000 can read up to AutoCAD 2003.
And each version can read each older version.
Jürgen Palme
Where are the files in question coming from? Maybe you can ask the sender to saveas the files in your (2000) format?
Or, you can ask someone here in the forum to do that (if we don't talk about hundreds of files 😉 )
Jürgen Palme
@jimschmidt wrote:
I only need 3 files saved down to R2000 format
Already in post #6 (two days ago) I offered to convert the files for you ...
Jürgen Palme
That would be great, but when I reply and try to attach the files I get a message "content type (application/x-dxf) does not match its file extension and has been removed."
Do you have an email address I can send them to?
Jim
@jimschmidt wrote:
... when I reply and try to attach the files I get a message "content type (application/x-dxf) does not match its file extension and has been removed."
Try ZIPping them, and attaching the .ZIP file.
here you go.
Jürgen Palme
FYI, if you open the files directly from the .zip file rather than first extracting them, then they will be read-only.
