Is it possible to view newer drawings in older versions of AutoCad (2000)
jimschmidt
Message 1 of 18
jimschmidt
I have AutoCad 2000 and drawings from newer versions that I need to view, cut and paste.  Possible or not?
Replies (17)
Message 2 of 18
Kent1Cooper
Find DWG TrueView [a free download from Autodesk], which has the ability to convert newer drawings to older file formats.
Kent Cooper, AIA
Message 3 of 18
j.palmeL29YX
The currently newest AutoCAD version 2022 can be read with AutoCAD 2018 and newer (they use the same file format).
For future AutoCAD versions we don't yet know it.
AutoCAD 2013 can read up to AutoCAD 2017
AutoCAD 2010 can read up to AutoCAD 2012
AutoCAD 2007 can read up to AutoCAD 2009
AutoCAD 2004 can read up to AutoCAD 2006
AutoCAD 2000 can read up to AutoCAD 2003.
And each version can read each older version.
Jürgen Palme
Message 4 of 18
pendean
Community Legend
Community Legend
>>>...I have AutoCad 2000... I need to view, cut and paste....<<<
Nope, you need a converter app to convert the DWG files down to your ancient version first https://knowledge.autodesk.com/support/dwg-trueview/learn-explore/caas/sfdcarticles/sfdcarticles/How...
Message 5 of 18
jimschmidt
I downloaded the true view app but its 64 bit and my old 2000 autocad and Windows XP is 32 bit and not compatable with true view 64 bit.  So maybe I'm stuck.
Message 6 of 18
j.palmeL29YX
Where are the files in question coming from? Maybe you can ask the sender to saveas the files in your (2000) format?
Or, you can ask someone here in the forum to do that (if we don't talk about hundreds of files 😉  )
Jürgen Palme
Message 7 of 18
pendean
Community Legend
Community Legend
TrueView 2019 and 2018 are both available 32bit and will open all DWG files through R2022:
https://knowledge.autodesk.com/support/dwg-trueview/learn-explore/caas/sfdcarticles/sfdcarticles/Whe...
Message 8 of 18
jimschmidt
Do any trueview files work with win XP?
the oldest (2017) requires win 10
Message 9 of 18
ChrisGriffinCencora
You can also download the 30-day trial and save down... or cut and paste from newest version to your stone tablet.😆
Message 10 of 18
pendean
Community Legend
Community Legend
WindowsXP? Now you've limited yourself to asking all your file senders to save down your files for you to R2000 format.
Sorry and good luck.
Message 11 of 18
jimschmidt
I only need 3 files saved down to R2000 format
Message 12 of 18
j.palmeL29YX
Already in post #6 (two days ago) I offered to convert the files for you ...
Jürgen Palme
Message 13 of 18
jimschmidt
That would be great, but when I reply and try to attach the files I get a message "content type (application/x-dxf) does not match its file extension and has been removed."
Do you have an email address I can send them to?
Jim
Message 14 of 18
Kent1Cooper
@jimschmidt wrote:
... when I reply and try to attach the files I get a message "content type (application/x-dxf) does not match its file extension and has been removed."
Try ZIPping them, and attaching the .ZIP file.
Kent Cooper, AIA
Message 15 of 18
jimschmidt
That worked - here are the zips
Message 16 of 18
j.palmeL29YX
here you go.
Jürgen Palme
Message 17 of 18
jimschmidt
I had to open them as "read only" but then I was able to "save as"
big thanks
Jim
Message 18 of 18
nrz13
FYI, if you open the files directly from the .zip file rather than first extracting them, then they will be read-only.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
