AutoCAD Forum
Intersection Snap is not snapping to true intersection
20 REPLIES 20
Message 1 of 21
3684 Views, 20 Replies
My intersection snap in Autocad 2013 is not working properly.  It shows the intersection snap but when I click on it, it doesn't make the line at the intersection.  It snaps to intersection fine but it doesn't actually hit the true intersection point.  It is always up to 0.0075 away from the true intersection point.  I have tried to uninstall and reinstall the Autocad, as well as reset to default settings.  Do you know how to fix this?
20 REPLIES 20
Message 21 of 21
HI BAHTING,
USE FLATTEN COMMAND TO THE OBJECTS,, ITS SEEMS THE OBJECT ARE NOT IN THE PLANAR.
HOPE THIS WILL HELP.
gUD LUCK,
VIRGILIO BENEDICTOS
AutoCAD Inside the Factory
