AutoCAD Forum
EDIT ARRAY
1 REPLY 1
287 Views, 1 Reply
EDIT ARRAY
Hi, Im working with autocad 2013 and when i enter a array i created to edit it I am missing the options panel. I did right click on the ribbon to make sure it is selected and it is checked off. Is there any other way I can get it back?
1 REPLY 1
hi sarah,
try to change you workspace to autocad classic at workspace swithing located at the
lower right of the window then change it again to your default workspace..
hope this will help you,
good luck,
Virgilio Benedictos
AutoCAD Inside the Factory
