AutoCAD Forum
Inserting counterbore and depth symbols into dimension text.
10 REPLIES 10
Message 1 of 11
54323 Views, 10 Replies
Hello. I am fairly new to AutoCAD 2017.   I am trying to insert a counter bore and depth symbols into dimension text.  When editing dimension text, I can find the diameter symbol, but cannot locate counter bore and depth.  Where can I find these?
Thanks in advance for your help!
10 REPLIES 10
Message 2 of 11
In Dimension Text Editor, Click Symbol Ribbon, and then Click Other...
See below an image.
Then You will get Character map Dialog box.
If you change Font to GDT, You will see Counterbore and depth symbols.
Message 3 of 11
THANK YOU!
Message 4 of 11
breeder
Thanks!!!
Message 5 of 11
simonquinn
i tried this, but it didn't work for me.  the depth symbol turned into an x when i pasted it.
Message 6 of 11
breeder
in reply to: simonquinn
Try with cap lock on or off, I can't remember. It is case sensitive.
Message 7 of 11
todd.rathier
Make sure the text font is GDT. Other fonts probably do not support that symbol.
Message 8 of 11
lbsceldiablito
I am having a similar problem with the countersink symbol in V2023 Windows. It comes across as a "W". I've tried alternate GDT fonts and upper- and lower-case when selecting and pasting.
Message 9 of 11
Nevermind, I found the solution.
Message 10 of 11
Joseph.Madden
I had the same problem were it was appearing as a W. Had to right click and disable "All Caps" and "Autocorrect cAPS Lock". Then paste it in again. I was able to reenable both once it displayed correctly.
Message 11 of 11
mvr_asp
same here
this is really frustrating
Forma Design Contest
AutoCAD Beta
