AutoCAD Forum
Insert View tool not showing dimensions
4 REPLIES 4
office6PUWT
411 Views, 4 Replies
office6PUWT
I'm really stuck as to why using the Insert View tool from the Layout tab is not showing any of my dimensions, I've not had this problem before and have attached the file in the hope that someone can shed light on exactly what's happening here?
4 REPLIES 4
in reply to: office6PUWT
I got ya.  The dimensions that you are using are annotative dimensions.  If you select the dimensions in the model go to the properties and add the necessary Annotative Scale.  If it's not on the list it won't show up... if it is then it will show up.  The dimension is designed to scale appropriately as well.
Your scale for them is set to 1:1 and the viewports are 1:2.
Alternatively you can set ANNOALLVISIBLE to 1 and they will always show.
pendean
pendean
Community Legend
Community Legend
Aren't you using AutoCAD for MAC?
office6PUWT
in reply to: pendean
office6PUWT
No I havre switched over having started my HND course as this was the prefered platform.
vinodkl
vinodkl
Hi @office6PUWT
@Anonymous is correct. You're dimensions are annotative and the scale which is set in modelspace (1:1) is not matching with the view's scale created using "insert view"(1:2).
You could also see that the hatch is also missing in the view since the hatch is also annotative. You can either set the system variable "ANNOALLVISIBLE" to "1" or remove the annotative properties of the dimensions and the hatch. Else match the annotative scale between the view and model space🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @office6PUWT
AutoCAD Inside the Factory
