How to remove this frame from layout
sergiolordelo342V2
sergiolordelo342V2
Hi there,
I am trying to learn about making layout, make view an so on. So, when i try to make this, it apeares the original black frame in layout, as shown below, and i can't remove that.
How can i do to solve this problem?
cadffm
This is a "help feature", it shows your the PAPER, depends on you current PAGESETUP (or start PLOT dialog)
Plotter, Plotarea, Paper(size), Origin, PlotScale.. the result that area.
Just for testing: Start PLOT command, choose your Plotter, Plotarea, Extents, Center, 1:1,  [APPLY] to layout & Cancel
The area changed now, right?
Paper & printable borders (the 'hidden'line inside the Paperarea) is an option, i prefer to turn it on, specially for beginners.
OPTIONS, Display, lower left corner you will find where to turn it ON/OFF
Upper left corner: [Colors] , you can set the LAYOUT color to white, a kind of white is default.
Note: Sometimes this helper tool(the paper position and size) is not up to date, but for usual it is.
Sebastian
sergiolordelo342V2
Thank you for your answer.
Indeed, if i try to plot this area has changed. However, in a real situation, if i send this file in a dwg format to someone, they couldn't see this drawing in a clean way. So, that was the reason for my concern!
I got to solve the problem, follwing the instructions you gave me,
Thank you very much.
