Is there a way to had it auto insert the user in the drawn by field? Based on computer ID or even workspace?
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
There are many ways to do this such as with a LISP routine, DIESEL code, and my favorite, using fields either by themselves or as attributes in a block.
I made a quick video that shows how I can insert a field and set it to a document property of Last Saved By. The same steps could be used to insert the date or even linked to custom Drawing Properties.
I hope this proves useful.
To put this in a block with an attribute, use the ATTDEF command with a Field
And then add the attribute to a block.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
hey, I'm trying to insert names into a drawing, and I would really like to modify the formatting of the field command "Login".
Login prints as a full "John Doe", but I need to match it to my standard "J. DOE" format
But, I noticed that Login is not the same as "loginname" in a deisel expression.
since I cant reformat the login Field, do you know how I can source the same name from a Login field in a Deisel Command?
thanks in advance
