insert pdf- scale - plot
v.mamali
v.mamali
hello everybody
i need an answer to an issue.
I want to insert an object (a pdf file for example which :
        1. i draw by hand a dwg in scale 1:50 in A4 paper size,
        2. then i scanned- less than 300 dpi -this paper so i get a pdf file)
into an autocad file and then to add some things like title etc and after to plot it again as an A4 paper size.
My question is why i cannot plot this A4 paper in 1:1 scale when i choose A4 paper size in my printer - i try several things and i have to plot it in 10:1 scale
the new autocad file has units unitless
thanks anyway
Vasso
Accepted solutions (3)
pendean
Community Legend
Community Legend
Post your DWG file, lets see what you are doing for our selves.
v.mamali
hi there,
the pdf file is A3 paper size and in scale of 1:50, scanned
the dwg file has in a cloud the A3 paper size
ps
forgive my ignorance, but i can do the same thing in Adobe InDesign without scaling anything
I hope to to do the same here because i use as a designer the cad files more often.
thanks anyway
Vasso
v.mamali
hi,
by mistake i pushed the button solved... Iam still waiting for an answer
thank you
Vasso
cadffm
1. Your red rectangle is wrong (or your setting for INSUNITS, because 4 = Millimeter and your rectangle is 1/1000)
2. Inside the PDF is a information for imperial (or a missing information, i am not a PDF professional, so i am not sure)
    The PDF Viewer use this information to scale the drawing, Acad import the real (raw?) data by ignoring these informations.
I said this is like Exif codes in images, some programs irgnore this information (to rotate the picture for example)
and some one use it. In some programs there is a optional setting for this.
In this case AutoCAD has NO setting, no option.
If you know there is an issue, you can use the scale factor in your pdf attach/import dialog (25.4)
Sebastian
