I've got a linetype issue that's been bugging me for a little while: is it possible to set linetype scales per viewport, or to turn off paper space scaling just for one line/linetype/layer?
I know that you can change linetype scales with various commands, or switch off scaling entirely, but I need to be able to turn off scaling for just one object.
The particular example is for road linemarking. We show a 1:1000 overall plan, then a 1:200 plan for intersection details. I need the linemarking to retain the real world scale/dimensions (eg. 600mm line and 600mm spacing for a Give Way line) at both of those scales, rather than having the spacing scale up to meet the viewport setting.
However, I need the rest of the linetypes in the view to scale up, to keep the plan tidy.
So is there a way to stop just the linemarking lines/layers/linetypes from scaling across different viewport scales? Or a way to control object/layer linetype scale per viewport, like other aspects in the Layer Properties panel.
Darcy
Solved by RobDraw. Go to Solution.
Solved by dan908. Go to Solution.
LTSCALE command and PSLTSCALE (System Variable) are a global drawing commands in both Model and Paper space layouts . you asked for a certain line/layer linemarking , i suggest to overlap this line in model space . i mean that to put two linemarking lines overlaped with different ltscale . now from paper space layout pick inside your VP and turn OFF or freeze unwanted case from layer command ( VP freeze tab ) .
in this way you've got your need in a certain line , and don't forget to do the same in the other VP's if there's any .
Imad Habash
refer to this article and see if helps. thanks
I don't think a linetype is appropriate for this. You need separate line segments.
Agreed. Line types are for schematic purposes only, they are horrible/not intended for representing real-world lengths such as fence posts or lane markings.
Using the measure command with a block of the markings would work. The block would be a 600mm line and the measure distance would be 1200mm. Now if you have curves - this wont work in those areaa. The measure command could still place a simple block where you could break (or trim) the center line to and from to create markings.
Use a no plot layer for the construction lines (and blocks to trim from on curves) and a plot layer for the final markings.
Or a lisp routine to divide the line into individual objects. I can't help with that.
Thanks for all the options everyone, all pretty good solutions, depending on the case.
As they're often on curves, best solution (at least for my case) is probably to set up a different linetype for different scales, and set that in the viewport.
That, or do it as segments, which is a pain for repeat editing, but it sounds like there's no fix-all answer anyway.
Cheers!
For what you are wanting to accomplish, I would also consider looking for a third party pavement marking program. Linetypes as they exist in autoCAD are very limited, and in many ways less capable that the 1980 methods of applying zip tape to mylar.
