I am sorry for my language skills, but I just learn englisch. Few days ago I received a plan of some surface:
Between contour 215 and 220 I have 5 meters, 3 lines - the distance between them is 1.25m. My teacher said, that I have to make indirect contours with 1m distance between them - I need to draw another 4 contour lines, but I have no idea how to generate such line that will be in 1/5 distance betwen i.e. contour 215 and 216,25. I hope, you understood what I mean.
I use AutoCad 2013. Please help me.
Solved by hgasty1001. Go to Solution.
IF I understood the question, if the contour lines are plines wouldn't dividing the space between the contours (1.25/4) and using that as an offset distance work?
Am I missing the mark?
HTH
DJ
If I understood good your post I try to reply.
I tried to move the line in way that you are describing but, I noticed that i.e. distance between two contours in first ellipse is another than in second one. Would be amazing if I could move whole line point by point (one line has several points; all contours are splines). Can I do this or there is no such tool?
The only reasonable way to generate a new contour curve is interpolating using the slope between curves.
Gaston Nunez
