AutoCAD Forum
In Paperspace (Layouts) how do you freeze one viewport so that it does not change?
11 REPLIES 11
Message 1 of 12
ktnalive
713 Views, 11 Replies
I have 4 viewports on one page within Paperspace each viewport needs some of the lines (layers) visible and the other viewports do not. How does one do this? I need each one "frozen" per se so that it does change when manipulating the lines in the other viewports (turning on or off, making bigger or smaller).
11 REPLIES 11
Message 2 of 12
Patchy
in reply to: ktnalive
Activate the viewport, then use Layer Properties, look for the column VP Freeze, click on the layers you don't want to show.
Message 3 of 12
pendean
This is how viewports in layouts work like that (from an almost identical post today):
https://forums.autodesk.com/t5/autocad-forum/how-to-make-a-change-to-one-layout-page/m-p/12749022#M1...
Message 4 of 12
cadffm
layers are global (in your dwg), but each viewport can "VP FREEZE" layers.
Layers which you need somewhere visible, have to be ON and THAW.
Now, go to your Layout, jump into one viewport (mspace) and open LAYER palette.
Search column VP FREEZE and use it.
But:
Viewports are just holes in a paper, so you can't have one and the same line in one viewport shorter than in another one , it is the same line!
If you need variants, you have to create copies of your objects
or you have to copy your file.
Sebastian
Message 5 of 12
ktnalive
in reply to: Patchy
freezing did not work.
Message 6 of 12
Patchy
Which column did you pick?  Use the one with a box .
Message 7 of 12
ktnalive
in reply to: pendean
Will this work if the object is a block or do I need to explode the block?
Message 8 of 12
ktnalive
Does this work with Dynamic Blocks or do I need to explode them?
Message 9 of 12
ktnalive
in reply to: Patchy
Yes, I have my objects in Dynamic Blocks and when I freeze the layer the entire object disappears.
Message 10 of 12
pendean
Try again please, first you have to be inside a viewport, not like this
But like this
Then open LAYER command and look for these columns to use in ViewPorts (VP named)
Message 11 of 12
pendean
Only if the content inside your dynamic blocks are on layers you never VPFreeze, as well as on layers you never VPFreeze either.
Message 12 of 12
ktnalive
Thanks, then I think the DBlock needs to be recreated since the entire drawing disappears after I hide one of the layers. That is under VPFreeze.
Forma Design Contest
