icons don't work
icons don't work
Message 1 of 14
icons don't work
I'm having problems with AutoCAD electrical 2016 today. I had clouds with question mark icons on all my icons.
I cuiunload ACAD.cuix and cuiunload ACADE.cuix and then cuiload acad.cuix and cuiload acade.cuix
then I did a profile reset.
Then did the cuiunload then load again. No luck
then I changed profiles. this profile shows the Icons but they don't work. if I click on the project manager folder, down on the command line I get "unknown command: aeproject".
If I click on the schematic tab then click on the Icon menu button, down on the command line I get "no function definition: ace_dlg_cip_chk"
I had this problem last year and got through it, it happened again.
any suggestions??
Replies (13)
Message 2 of 14
john.vellek
HI @Anonymous,
Did the Reset Settings to Default work for you? Can you logon as a different user to see if everything works?
John Vellek
Message 3 of 14
hencoop
If you keep your old email correspondence, search them for what you did to fix it. (I depend upon mine this way).
It sounds like your AutoCAD Support File Search Path and/or your Customization Files paths got wiped out.  This can happen if your locations are on a network share and the connection gets broken before AutoCAD is initially opened.  If you save a backup copy of your profile you can use that to restore them after you get the network connection restored.
Henry C. Francis
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
Message 4 of 14
Project Manager works now.
Under the projects tab
When I click on title block setup or title block update, nothing happens
Under the schematic tab
clicking on Icon menu doesn't do anything
Message 5 of 14
john.vellek
Hi @Anonymous,
What steps have you taken so far?
John Vellek
Message 6 of 14
I did the reset setting to default as you mentioned.
Message 7 of 14
john.vellek
HI @Anonymous,
Did you also try logging on with a new user account? If it works there then that means that your profile is damaged in some fashion. If it doesn't work then I suggest a clean uninstall and then reinstall to fix the issues.
John Vellek
Message 8 of 14
We are a small company and don't have an IT dept.
Could I get someone to walk me through on the phone?
Message 9 of 14
john.vellek
Hi @Anonymous,
You can schedule a call or try a CHAT from your account page.
If you have other users, have one of them try logging onto your computer to see if it works properly.
John Vellek
Message 10 of 14
Ok, I will after lunch
Message 11 of 14
john.vellek
Hi @Anonymous,
Did the other user logon to your computer? Did everything work normally then?
John Vellek
Message 12 of 14
I did a complete uninstall, then installed ACADE 2017.
Message 13 of 14
john.vellek
Hi @Anonymous,
So everything is working normally then?
John Vellek
Message 14 of 14
yes
