AutoCAD Forum
I cannot see road markings in autocad that were done in key lines
3 REPLIES 3
628 Views, 3 Replies
I cannot see road markings in autocad that were done in key lines.
Should look like this:
3 REPLIES 3
Valentin-WSP
@Anonymous ,
Welcome to the AutoCAD forum.
If you are working in AutoCAD, you are in the right location.
If you are working in KeyLINE, then consider posting on their forum >>LINK<<
If in AutoCAD - Try the suggestions from this link:
Note you can also contact KeyLINE Support.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
imadHabash
 As much as i understand ... I think that your drawing lost an attached xref . type XREF command .. and make a screenshot for the dialog ( Palette )  and post it here ?
Imad Habash
pendean
Keylines support is over there https://community.keysoftsolutions.com/forums/keylines
As noted by others you have either frozen layers or missing XREFs, or your other content got erased.
Forma Design Contest
AutoCAD Beta
