I cannot see road markings in autocad that were done in key lines.
Should look like this:
@Anonymous ,
Welcome to the AutoCAD forum.
If you are working in AutoCAD, you are in the right location.
If you are working in KeyLINE, then consider posting on their forum >>LINK<<
If in AutoCAD - Try the suggestions from this link:
Note you can also contact KeyLINE Support.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
As much as i understand ... I think that your drawing lost an attached xref . type XREF command .. and make a screenshot for the dialog ( Palette ) and post it here ?
Imad Habash
