I cannot erase some shapes in AutoCAD 2020
Message 1 of 31
Hi All,
I can't seem to edit/erase some shapes in AutoCAD 2020. After pressing the erase button in the modify panel, the shapes and the enter button, nothing happens. The shape is still there. I'm not sure why.
Thanks for the help.
Kind regards,
Ian
Replies (30)
Message 2 of 31
vinodkl
Type in the command "PICKFIRST" and set it to "1"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 31
imadHabash
is that means that you're able to erase others ? if yes ... you may need to check your layer status for those undeleted shapes .
Imad Habash
Message 4 of 31
I've written "PICKFIRST" and then written "1" but it's still not working.
Message 5 of 31
I've checked all of them. They are all unlocked.
Message 6 of 31
imadHabash
Ok... what do you mean by Shapes ... is it blocks or xrefs or lines .... ?
Imad Habash
Message 7 of 31
ACAD_PROXY_ENTITY
Color Yellow ByLayer
Layer Instrument
Linetype ByBlock
Message 8 of 31
imadHabash
Aha ... try to delete them as mentioned here . >> Click <<
Imad Habash
Message 9 of 31
It won't let me load DelProxy.
I get an error message saying, "This file does not have an app associated with it for performing this action".
Message 10 of 31
vinodkl
These are the proxy object which comes from other AutoCAD Vertical products(AutoCAD Architecture, AutoCAD Mechanical etc) and you need to export the drawing to work with plain AutoCAD.
To do that type in the command " AECTOACAD" and tap the enter the twice, which would export the drawing to be compatible with plain AutoCAD. The drawing will be saved in the same location where the main drawing is with prefix "ACAD-"
Message 11 of 31
imadHabash
would you try -EXPORTTOAUTOCAD command and see if any changes ?
Imad Habash
Message 12 of 31
Same as before. It is still not working.
Message 13 of 31
I'm using Autodesk AutoCAD 2020 at the moment.
Message 14 of 31
I get an error message saying, "This file does not have an app associated with it for performing this action. Please install an app or, if one is already installed, create an association in the Default App Settings page".
Message 15 of 31
Alfred.NESWADBA
can you please upload the dwg-file and describe which of the entities can't be removed?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 16 of 31
I'm sorry, I can't, the file is highly confidential. I can only say that when I press the shapes, I only end up with 'command:'.
Message 17 of 31
Alfred.NESWADBA
are you able to use copy & paste within this drawing with just one line?
- alfred -
Alfred NESWADBA
Message 18 of 31
It does let me copy it but not paste it to the next drawing sheet
Message 19 of 31
Alfred.NESWADBA
please try to use command _SAVEAS and select the filetype "DXF-2000" ... close the file.
Now try
  • to open the DXF ... anything better
  • create a new dwg-file and use command _INSERT to insert this DXF file ... anything better?
- alfred -
Alfred NESWADBA
Message 20 of 31
Nope. It still doesn't work.
