Qudrant issue
Qudrant issue
CDLLT
Message 1 of 9
Qudrant issue
CDLLT
Does anyone know why the quadrant of a circle does not follow a new ucs position and always follows world ucs. When you need to put holes in an object that is not in world ucs this makes snapping to the quadrant while following that object impossible.
Replies (8)
Message 2 of 9
cadffm
Because it is not a circle, it is a 3Dsolid (perhaps) ? then it is not the same and usual,
the quadrant on  a circle has nothing to do with the circle object data, on  a 3Dsolid it is.
Sebastian
Message 3 of 9
CDLLT
Hi Betreff,
Thanks for your reply. But the same thing happens on 2D circles.
Message 4 of 9
vinodkl
Read this: Click Here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 9
cadffm
I don't know and without a sample i can't check it.
Upload a file with (only) one circle with the issue and your settings.
Bitte wirklich nur ein Objekt und die entsprechende Einstellungen, so muß man nicht erst noch suchen, thx.
Sebastian
Message 6 of 9
Kent1Cooper
Admittedly not in 3D, but it's not working as you describe for me.  I drew the white Circle in the WCS, rotated the UCS 45 degrees, started a Line command, and asked for QUAdrant Osnap, and it's finding the Quadrant in the current UCS:
[That happens to be in Paper Space, but I get the same result in Model Space.]
Kent Cooper, AIA
Message 7 of 9
CDLLT
Hi Kent1Cooper
Yes I get the same in 2D as you say. I think it must be a 3D thing then when using the cylinder command to make holes, as my example shows. I guess it just one of those CAD things I will have to live with, does seem a bit daft though.
Message 8 of 9
cadffm
Yes it is.
So you can mark the first answer#2 as solution (and all other replies too if you like)
Solved in the sense of completely answered.
Sebastian
Message 9 of 9
GrantsPirate
A workaround is to set DELOBJ to 0 to leave 2D objects, or set to -3 to be prompted to delete or not.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
