Anuncios
I cannot erase some shapes in AutoCAD 2020
No aplicable
Hi All,
I can't seem to edit/erase some shapes in AutoCAD 2020. After pressing the erase button in the modify panel, the shapes and the enter button, nothing happens. The shape is still there. I'm not sure why.
Thanks for the help.
Kind regards,
Ian
0 Me gusta
Responder
1.911 Vistas
30 Respuestas
Respuestas (30)
Alfred.NESWADBA
do you have Map3D or Civil3D?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
Whenever I try to delete it, I only get 'command: _erase 1 found'
0 Me gusta
No aplicable
Nope. The drawing I have just now was done by somebody else.
0 Me gusta
No aplicable
BUMP
Need help.
0 Me gusta
Alfred.NESWADBA
Can't you ask this person to remove or explode this object?
>> BUMP.
Kidding?
How much more suggestions within an hour are you expecting than you have got?
The solution would be much more easy if you could send us the dwg-file, maybe delete everything else (so only the critical object is visible), save this file with a new name and upload this file.
- alfred -
Alfred NESWADBA
0 Me gusta
cadffm
@Anonymous  schrieb:
BUMP
Need help.
after 10minutes silence?
cheeky..
And are you really not abler to upload a copy with the proxy elements only?
Set PROXYNOTICE = 1 and open the file, there is a list
of one or more missing applications - share the application- and company names.
May i ask "what represent" the object?
a wall, a gear, a tree ?
Sebastian
0 Me gusta
Alfred.NESWADBA
you might also try this free (great) plugin:
https://apps.autodesk.com/ACD/en/Detail/Index?id=1498235021060360128&appLang=en&os=Win32_64
- alfred -
Alfred NESWADBA
0 Me gusta
s.borello
Check sys var "pickfirst" and set it to 1.  Ensure layers are not locked.
0 Me gusta
No aplicable
No worries. It's working now. Thanks for helping anyways.
0 Me gusta
Alfred.NESWADBA
May I ask what the solution was now?
- alfred -
Alfred NESWADBA
0 Me gusta
imadHabash
it will be great if you share with us the solution . :cara_con_una_leve_sonrisa:
Imad Habash
0 Me gusta
