AutoCAD Forum
I can’t stretch, move anything
2 REPLIES 2
dilsmails
2571 Views, 2 Replies
Hi all I need an urgent help. What is that mark in the shown image. How can I remove this? Difficult to work with that. I can’t stretch, move anything. If I am stretching or moving something the related objects are also coming with that. Please help.
Dileep
2 REPLIES 2
nestly2
in reply to: dilsmails
The icon indicates the object has a Constraint applied, (which you already figured out)
Use DELCONSTRAINT from the command line, or from the Parametric tab on the Ribbon to remove existing Constraints, and then make sure CONSTRAINTINFER = 0 to prevent them from  being automatically applied to new objects.
dilsmails
in reply to: nestly2
thank you
Dileep
Forma Design Contest
AutoCAD Beta
