I have a batch of drawings that I need to convert to PDF. When I do the conversion most of the drawings convert fine but several of the drawings convert but they are a fraction of the size of the page that I'm converting them to. Most of the drawings convert to about the size of the paper I'm designating but the problem drawings are converting to a tenth of the page size. I have attempted to scale the drawings up and then convert them which is somewhat better but still not like the other drawings. What I need to do is have the drawings convert to the 17 X 11 size sheet and they seem to be stuck in a one size fits all mode. I have attached an example of the converted document for an example. Can anyone help?
Can you attach a screen shot of your page setup for one of the problem drawings?
In addition to what Dean suggested, you might want to look into using layouts for plotting. They are a lot easier to use if you need to have your drawings plotted to scale.
