I'm trying to do a duct sytem for hvac. I'm trying to put this... Shoe that is a Branch Connection of 45°. I found a Fabrication Part but I honestly don't know how to use it. If anyone can help me please!!!
I'm putting an image of the Shoe I found on Revit and the one that I want on Autocad.
Solved by IslamSakr. Go to Solution.
If you want a shoe branch for autocad you better should draw something in Autocad.
Better to ask this question in the Autocad forum.
Louis
Please mention Revit version, especially when uploading Revit files.
Hey Marco, you can find a revit family of shoe branch under autodesk library folder ''Libraries\Duct\Fittings\Rectangular\Branches"
It's called ''Rectangular Shoe Branch - Slip Joint.rfa''
Is not for Autocad. I want it for Revit. Sorry if I didn't express myself clearly. I want a shoe branch in Revit and I want it like the one that i on the pic of AutoCAD that I upload.
Thank you very much! I found the family.
I jut need to know how to edit it so I can use the sizes that I need. But really Thank you.
