When I run audit on a particular file, it repairs 2 objects every time, even if I run the command back to back. How do I determine which objects are being repaired so I can maybe delete them or do something else to them to prevent this from recurring. I've provided a screenshot of the output below. Also, there are several "scale invalid" items that I would like deal with also.
This is happening in both 2025 C3D and vanilla AutoCAD.
Solved by brian.strandberg. Go to Solution.
the id of each object are in ( ) , it's called HANDLE
but that doesn't help you or?
1. Can you share the file as ETRANSMIT zip?
If not:
Open the file by RECOVER
Run AUDIT yes
SAVEAS <another name or folder>
Fileformat: DWG 2018.
Open this new file, still a problem?
2. Your file format is?
Sebastian
You can find the object by using a lisp statement like this. Replace the portion in quotes with the object handle in question.
(command "List" "SI" (handent "152CF"))
I was able to use this list function to determine the offending object was a pdf underlay that I thought was deleted and also wasn't listed under file references. I wasn't able to use the select command with the handle name to select it, but was able to select it using qselect.
The invalid scale problem was a couple of blocks that were defined as scale uniformly, but the objects had a different z scale. Not sure how that did or can happen.
