how to snap at intersecton points of a base view created from 3d for dimensionig
I have a 3d drawing from which I have created base views in paperspace. Now I want to snap at intersection points of lines in base views for the purpose of dimensioning but i don't see any method of doing it. please help me out because my drawing needs to be dimensioned at intersection points only
Is your Intersection object snap turned on?
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
Viewbase views that are orthogonal can be dimensioned by using Osnaps. Isometric views cannot be dimensioned in this manner. I workaround this limitation by creating construction lines in paperspace that are based upon the intersections/vertices and then dimension from them.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
murray-clack
If you are trying to snap to an intersection of 3D lines that are at different elevations, you can use the "Apparent" Object Snap
