Hello, I have AutoCAD 2016 Student edition on a Dell laptop with Windows 10 that I'm using for my engineering CAD drawing class. I have been trying to figure out why some icons are so small and some are decent sized. It seems like some scaling is off and I don't know how to fix it. A lot of the icons and some of the text is so small that I cannot read it. I've looked on google and didn't have any luck? Any suggestions?
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
Welcome to the Autodesk Community!
You are seeing symptoms of a known issue. Currently AutoCAD does not support higher resolution displays. I suggest you reduce your resolution to 1920 or lower and set your Windows font size to 100-125%.
Please let me know if this helps your issue.
