I have several large size drawing to export from Layout space to a new drawing. These drawing can be up to 27mb to 30mb in file size. Sometimes it takes close to an hour, if it exports without failing. (Failures are coming from hatchings in the drawings. I have to make sure any hatch is not visible.) Is there a better way to export form layout space to a new drawing with out taking so long. I have 5 or more Layout tabs to export in each drawing. I have several layers stacked on top of each other to mimic each floor lever of a tower, Each level has equipment, duct work and notes, Then I use layout space to freeze layers in each viewport as needed. Any recommendations will be greatly appreciated.
Sam
AutoCAD 2015
