I’m trying to write a script for a simple animation but I can’t seem to find how to save scripts as .scr with apple script editor. When I try to open said script with autocad, it doesn’t find anything. Thank you in advance!
Solved by cadffm. Go to Solution.
You mean, the file-select dialog appears but there isn't any file in the right folder?
Then your file has another file extension, not scr
https://www.idownloadblog.com/2014/10/29/how-to-show-or-hide-filename-extensions-in-os-x-yosemite/
Sebastian
As Alfred wrote, it is not a Autocad case, it is also not a Autocad for mac case,
it is a basic knowledge Computer case.
If your editor can not save a file with *scr extension,
then change the extension after creating with your file manager.
(in windows for example the EXPLORER).
I am not a mac user, so i dont know what the standard file explorer is on mac, but you know it i guess.
Sebastian
