AutoCAD Forum
How to print a pitcure with text over it??
17 REPLIES 17
Message 1 of 18
1357 Views, 17 Replies
I imported a JPEG picture that has a dark background. I put words over the top that are white in color with a 40% transparancy. When i go to print or save as a PDF the word do not show up, it looks lime they are still black. Please help
17 REPLIES 17
Message 2 of 18
imadHabash
you may need to tick the Plot transparency option in plot dialog . can you make a screenshot for your issue ?
Imad Habash
Message 3 of 18
gotphish001
You can put a wipeout around the text so it masks a small rectangle over the picture. Click on the text and right click and pick text editor. There's a button called mask in the ribbon. There's a few options. Try them and see which you like best.
Nick DiPietro
Cad Manager/Monkey
Message 4 of 18
-FDC-
You should put some transparancy to the jpg as well.
Either the layer it is on or in the properties
Message 5 of 18
Alfred.NESWADBA
If you are using AutoCAD 2018 and you used true color 255,255,255 then change the value to 254,254,254 ... there is a small bug with true-color-white and transparency.
Otherwise ... uploading the DWG + the JPG would help us to see what you have. Not seeing the text could be so much (on a no-plot layer, in the draw order behind the image, visual styles set to handle 3D, ...).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 6 of 18
Thank you all! I have the text showing up now by using the layer setting. But now the text is not showing the transparency. It does not lighten as I change the number in the Mtext properties. I’m sure this is an easy fix but i don’t see an option to show transparency. Ideas?
Message 7 of 18
imadHabash
i think that the problem is NOT in the text transparency , the darkness of the image is the case.
Imad Habash
Message 8 of 18
-FDC-
Try to set the text in another color (yellow or black).
Message 9 of 18
But the look of the text is not changing as i change the text transparency?
Message 10 of 18
Alfred.NESWADBA
Does not change on the display: set TRANSPARENCYDISPLAY to 1
Does not change on the plot: make sure "Plot transparency" is activated in the plot dialog
Yes, if we have the data it might be easy.
- alfred -
Alfred NESWADBA
Message 11 of 18
-FDC-
Here you see an example.
Image on a layer with 50% transparancy.
Text on a layer with 70% transparancy.
Text should be TrueType though (not shx)!
To plot you schould check "plot transparancy"
Message 12 of 18
Got it!! Thank you Alfred!
Setting the transparancydisplay to 1 fixed it
Thank you everyone!
Message 13 of 18
Alfred.NESWADBA
great, thank you for your feedback, good to know you got it working!
- alfred -
Alfred NESWADBA
Message 14 of 18
Actual. That fixed it in autocad but when I go to print or save as pdf the text color look 100% bright
Message 15 of 18
Alfred.NESWADBA
Please use _PLOT and use the driver "DWG to PDF.pc3" and make sure the checkbox for "plot transparency" is active in the plot-dialog.
There does not exist a "Save As" to PDF, if you mean command _EXPORTPDF then please use _PLOT, there are more options for the output.
If that does not work (and you want to avoid a day long try-and-error) please show us your data.
- alfred -
Alfred NESWADBA
Message 16 of 18
This is very helpful. I am new to this forum. How do i attach a screenshot?
Message 17 of 18
-FDC-
Message 18 of 18
Alfred.NESWADBA
Not a screenshot, in images we can't see your plot settings.
Please upload the dwg + the image you used in the dwg + the PDF you get when you plot.
Best would be to open your drawing, run commmand _ETRANSMIT and create a ZIP file from your dwg and your referenced files like the image (and CTB/STB if you used one).
When you are then in your internet browser to type the reply to this post you see one line below the text-input box a line with "Attachments" ... there you can attaach this zip file.
- alfred -
Alfred NESWADBA
Forma Design Contest
