I wanted to know if AutoCAD 2015 had a function that would allow me to take a 3D Spiral Staircase and flatten it? I need to machine parts for a spiral staircase that I have a 3D model of however in need to get it into a 2D plane so I can machine the parts on my CNC router. Any suggestions would be greatly appreciated.
Solved by john.vellek. Go to Solution.
Solved by imadHabash. Go to Solution.
put your 3D model at the face (Top plan) that you need it then use FLATSHOT commad.it will bring a 2D block of the top plan that you asking for.
Imad Habash
Hi @Anonymous,
There are a variety of ways this can be done:
Seasoned AutoCAD users of course are familiar with the FLATTEN Command.
But there are others ways of getting this to work.
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
