AutoCAD Forum
How to Flatten a Spiral Staircase
3 REPLIES 3
623 Views, 3 Replies
I wanted to know if AutoCAD 2015 had a function that would allow me to take a 3D Spiral Staircase and flatten it?  I need to machine parts for a spiral staircase that I have a 3D model of however in need to get it into a 2D plane so I can machine the parts on my CNC router.  Any suggestions would be greatly appreciated.
3 REPLIES 3
imadHabash
put your 3D model at the face (Top plan) that you need it then use FLATSHOT commad.it will bring a 2D block of the top plan that you asking for.
Imad Habash
john.vellek
Hi @Anonymous,
There are a variety of ways this can be done:
Seasoned AutoCAD users of course are familiar with the FLATTEN Command.
But there are others ways of getting this to work.
  • VIEWBASE – This command allows you to place various views (even section views) of your AutoCAD model into a paperspace layout. Once there you can change scale and visibility such as hidden, visible, shaded, etc. Use EXPORTLAYOUT to take these views and create a 2D only drawing.
  • FLATSHOT – This command will create a 2D block that represents the edges of 3D objects and inserts it into your drawing. The block can then be exploded for additional changes.
  • SOLPROF – This command will create a 2D version of a 3D solid with the options of creating layers for visible and hidden lines.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Forma Design Contest
AutoCAD Beta
