Hi there! someone knows how tho fix this? the pline is closed and the only problem is when I change the direction arc and is not tangent to the line.
Gustavo Ubriaco Contreras
Solved by Kent1Cooper. Go to Solution.
Already is a closed pline like I show in the image
Explode the polyline and add a fillet with a radius equal to one half the width then use pedit to recreate the polyline.
Remove the polyline width set <0>.
command prompt, enter stylesmanager. Right-click a CTB or STB file. Click Open.
In the Plot Style Table Editor, Table View tab, click the Line Join Style, Lineweight & Fill Style (solid) field for the plot style you want to change.
Check Plot Preview.
Another options this is a code for making the end of each segment perpendicular
BREAK
[PICK PLINE]
F
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
This kind of thing has always been the case with corners between line and arc segments when they are not tangential. If you can introduce even a very short line segment at the end of the arc segment, just long enough to get past half the Polyline width, it will miter appropriately with the other line segment:
Sorry for the late answer, thank you so much your answer is the best idea I have it too but I did think maybe there was another way to fix the unions maybe in the system.
