AutoCAD Forum
How to fix the width unions in a pline
8 REPLIES 8
Message 1 of 9
GustavoUbriaco
433 Views, 8 Replies
Hi there! someone knows how tho fix this? the pline is closed and the only problem is when I change the direction arc and is not tangent to the line.
Gustavo Ubriaco Contreras
8 REPLIES 8
Message 2 of 9
beyoungjr
in reply to: GustavoUbriaco
Please select all objects and use the JOIN command.  Then double-click the polyline and click the CLOSE item on the list.
Does that help?  If no, post your file so I can have a look.
Blaine Young
Senior Engineering Technician, US Army
Message 3 of 9
GustavoUbriaco
in reply to: beyoungjr
Already is a closed pline like I show in the image
Message 4 of 9
beyoungjr
If it were closed then the left intersection of the arc and line would be mitered.
Attach the drawing and I'll look!
Blaine Young
Message 5 of 9
leeminardi
Explode the polyline and add a fillet with a radius equal to one half the width then use pedit to recreate the polyline.
lee.minardi
Message 6 of 9
beyoungjr
in reply to: leeminardi
I was getting there but wanted to see why the strange intersections first.
Blaine Young
Message 7 of 9
jayhar
Remove the polyline width set <0>.
command prompt, enter stylesmanager. Right-click a CTB or STB file. Click Open.
In the Plot Style Table Editor, Table View tab, click the Line Join Style, Lineweight & Fill Style (solid) field for the plot style you want to change.
Check Plot Preview.
Another options this is a code for making the end of each segment perpendicular
BREAK
[PICK PLINE]
F
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 8 of 9
This kind of thing has always been the case with corners between line and arc segments when they are not tangential.  If you can introduce even a very short line segment at the end of the arc segment, just long enough to get past half the Polyline width, it will miter appropriately with the other line segment:
Kent Cooper, AIA
Message 9 of 9
Sorry for the late answer, thank you so much your answer is the best idea I have it too but I did think maybe there was another way to fix the unions maybe in the system.
AutoCAD Inside the Factory
