How to fix the width unions in a pline
GustavoUbriaco
GustavoUbriaco
Hi there! someone knows how tho fix this? the pline is closed and the only problem is when I change the direction arc and is not tangent to the line.
Gustavo Ubriaco Contreras
Replies (8)
beyoungjr
Please select all objects and use the JOIN command.  Then double-click the polyline and click the CLOSE item on the list.
Does that help?  If no, post your file so I can have a look.
Blaine Young
Senior Engineering Technician, US Army
GustavoUbriaco
Already is a closed pline like I show in the image
beyoungjr
If it were closed then the left intersection of the arc and line would be mitered.
Attach the drawing and I'll look!
Blaine Young
leeminardi
Explode the polyline and add a fillet with a radius equal to one half the width then use pedit to recreate the polyline.
lee.minardi
beyoungjr
I was getting there but wanted to see why the strange intersections first.
Blaine Young
jayhar
Remove the polyline width set <0>.
command prompt, enter stylesmanager. Right-click a CTB or STB file. Click Open.
In the Plot Style Table Editor, Table View tab, click the Line Join Style, Lineweight & Fill Style (solid) field for the plot style you want to change.
Check Plot Preview.
Another options this is a code for making the end of each segment perpendicular
BREAK
[PICK PLINE]
F
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Kent1Cooper
This kind of thing has always been the case with corners between line and arc segments when they are not tangential.  If you can introduce even a very short line segment at the end of the arc segment, just long enough to get past half the Polyline width, it will miter appropriately with the other line segment:
Kent Cooper, AIA
GustavoUbriaco
Sorry for the late answer, thank you so much your answer is the best idea I have it too but I did think maybe there was another way to fix the unions maybe in the system.
