Hi all,
i am trying to change the size of the text of the 'dimensions' in this drawing. However they are in a block and when you edit the block they are no longer dimensions as it seems they have already been exploded?
Is there any way to change the size of all the text whilst keeping the justification correct i.e centre above the dim line.
Thanks for any suggestions.
Solved by user181. Go to Solution.
You could select a text entity and right click and choose select similar to select all text. Then on the properties palette change the justification to bottom center and then change the height. They should stay in same location that way.
