How to draw a simple oblong with holes in it - and text?
Message 1 of 23
Hi there,
I am trying to use AutoCAD to create a '.dxf' file for a front panel (of a case) for Modushop.biz's CNC machine.
I have done this before using Visio (which can output a .dxf file) but they have a new CNC machine which seems to have difficulty reading the text produced by a Visio .dxf file.  So Modushop.biz suggested I use AutoCAD, instead.
 All I am trying to do is:
  • create a rectangle 124 x 44mm
  • put a text box inside it, and also
  • put some 9mm holes inside the rectangle.
But I have absolutely no idea how to achieve this!  Smiley Sad
Thanks for your help.
Andrew
Replies (22)
Message 2 of 23
Kent1Cooper
Not knowing how much you already know about AutoCAD, but assuming almost nothing from your description....
Read about the RECTANG, TEXT and CIRCLE commands in Help.  Depending on the arrangement of the holes, ARRAY might be useful.  But questions arise:
Are you talking about a 2-dimensional drawing, or constructing a 3D  solid model?  If a 3D model, other commands would be involved, such as PRESSPULL, or maybe BOX-and-CYLINDER [in lieu of RECTANG-and-CIRCLE] or EXTRUDE [if you start with RECTANG-and-CIRCLE] in combination with SUBTRACT to "cut" the holes.
When you say "text box," does that mean an actual box around the text content, or just text?  If a 3D model, is the box a recess, or a raised area, or...?  Regular AutoCAD Text isn't 3D-capable, but there are things you can do to make the shapes of the characters into 3D forms.  [But they won't retain their textual characteristics, such as the ability to edit the contents.]
Kent Cooper, AIA
Message 3 of 23
j.palmeL29YX
Hi Andrew,
where, at which point do you have diffuculties? Have you any experience with AutoCAD?
The rough steps:
- Draw a rectangle
- Draw the text
** explode the text to get closed polylines, this is an own issue
- draw circles (holes)
- saveas .dxf-file
and last not least: which AutoCAD version do you want to use?
Let us know more detailed what you need (how many holes, where to palce the holes, more informations about the text [size, font, content, style, ...]) and you will get more detailed help.
cadder
Jürgen Palme
Message 4 of 23
john.vellek
Hi @redwood.andrew,
You have some good suggestions in this thread.  Since you are new to AutoCAD I thought I would make a quick video that shows some of the steps.  I don't go into a lot of detail on how to make exact placement of geometry but this might be enough to get you started.
John Vellek
Message 5 of 23
Thank you Kent.
Yes, a 2D dwg is all I want to do.
I will read about those commands in Help.
Andy
Message 6 of 23
Oh, and when I say 'Text box' - I'm just using "Visio-speak"!
All I want to do is put an instruction on the diagram to engrave a word - like 'AD24QS'.
Andy
Message 7 of 23
Thank you Cadder.
I have zero experience with AutoCAD.  Smiley Sad
Sure the steps are as you stated.  But what commands do I use to draw the rectangle?
What I see when I open AutoCAD is a screen that looks like graph paper - so, as the start, how do I create a dimensioned rectangle on this?
Andy
Message 8 of 23
And now I've looked at the AutoCAD screen ... I cannot find a 'Help' button.  I would've expected to see it on the top line of the screen (where 'Home', 'Insert' & 'Featured Apps' are)?
Andy
Message 9 of 23
Thanks, John, for doing the video.
My first question is ... some commands appear on the LHS of the screen, centred. What button did you click on to get these to appear?
BTW, my learning style is heavily slanted towards text, rather than visuals.  IOW:
  • click on 'Rectangle'
  • place on screen
  • extend width until the desired length is reached
  • extend height until ....
Andy
Message 10 of 23
Kent1Cooper
@Anonymous wrote:
 ... I cannot find a 'Help' button.  I would've expected to see it on the top line of the screen (where 'Home', 'Insert' & 'Featured Apps' are)? ….
F1 button, or HELP is a command name you can type in, or this at upper right  [may vary by version and theme]
Kent Cooper, AIA
Message 11 of 23
Thanks, Kent.
I am using AutoCAD 2018 Student version - and this doesn't show a '?' in the top right of the screen.
However, pressing the F1 button brought up a window headed "Autodesk AutoCAD 2018".  One of the links on this screen was "AutoCAD 2018 Preview Guide" - which I thought might be of use to me?  However, clicking on this link brought up a document entitled "AutoCAD 2018 and AutoCAD LT 2018Preview Guide" - which gave no instructions in its 21 pages of how to do a simple thing like draw a rectangle!!
Typing "Help" into the bottom left of the AutoCAD screen brought up a pdf entitled "Using the LIFEBOOK Application Panel", which I thought was quite bizarre???
So I am as bereft as I was before.  Smiley Sad
Andy
Message 12 of 23
OK, from pressing F1 and doing some more reading (further down the topic list), I have drawn a rectangle on the screen.
Now I need to dimension it.  This is not clear.  How do I put:
a)  d1=124.00, and
b)  d2=44.00?
And I hit F9 - as I would like the rectangle to start on a major horizontal line and a major vertical line ... but couldn't see any result?
Andrew
Message 13 of 23
Hi John,
Looking at your video,  I couldn't see how you got "D" to appear on the screen?
Can you explain?
Andrew
Message 14 of 23
Can you tell me if it is possible to import a '.dxf' file into AutoCAD - which would then draw a diagram in AutoCAD?
(Then, I could create a diagram in AutoCAD by importing the .dxf file produced by Visio ... and then output a .dxf file from AutoCAD which, hopefully, Modushop's CNC machine will be able to interpret correctly.)
Andy
Message 15 of 23
j.palmeL29YX
You can open a .dxf-file in AutoCAD, if you in the file-open-window choose the filetype DXF. (see attached pic).
Then you can use the saveas command and choose in the saveas window one of the possible .dxf-formats.
You must test, which of the possible formats is useful for you.
cadder
Jürgen Palme
Message 16 of 23
Brilliant - thank you cadder!  Smiley Very Happy
My Visio dwg has been imported.  And I have just exported a .dxf file (AutoCAD 2018 format) and sent it off to Modushop - so they can tell me whether or not it is compatible with their new CNC machine.
The only problem I am worried about is that, somehow, the text - that appears clearly in the AutoCAD drawing (after the import from Visio) - is not in exactly the right format??
Anyway, will see in the next day or so!
Thank you for your help so far.
Andrew
Message 17 of 23
j.palmeL29YX
If you want to send the .dxf to a CNC machine, I guess you must explode the text to Lines/Polylines before.
One way to do this is demonstrated by @john.vellek in Posting #4 (starting at 1:10 min).
Here another way how I would do it:
https://autode.sk/2AjE6TP
Maybe you must draw some additional "bridges" (for letters with inner contours) not to lose this areas. If you wish I can show it in a next screencast.
cadder
Jürgen Palme
Message 18 of 23
Thank you, cadder for those suggestions.
I will wait until I hear back from Modushop, before I do anything.
Andy
Message 19 of 23
Aaah, sadly, importing the .dxf file from Visio into AutoCAD - and then "Saving as" dxf-2018 (or even dxf-2007) - produces an error at Modushop's end.  Smiley Sad  The file appears to be blank???
Andy
Message 20 of 23
j.palmeL29YX
@Anonymous  schrieb:
... dxf-2018 (or even dxf-2007) - produces an error at Modushop's end.
and above
Then you should ask there which format they need
If you can see the content of the drawing in AutoCAD, then the file is not blank - "only" it can't be read at the destination side.
Can you post here an example .dxf file which works on the CNC - they should have such files - and also your not working dxf? Maybe we can explore the differences or what causes the problem(?).
cadder
Jürgen Palme
