AutoCAD Forum
How to draw a simple oblong with holes in it - and text?
22 REPLIES 22
Message 1 of 23
2474 Views, 22 Replies
Hi there,
I am trying to use AutoCAD to create a '.dxf' file for a front panel (of a case) for Modushop.biz's CNC machine.
I have done this before using Visio (which can output a .dxf file) but they have a new CNC machine which seems to have difficulty reading the text produced by a Visio .dxf file.  So Modushop.biz suggested I use AutoCAD, instead.
 All I am trying to do is:
  • create a rectangle 124 x 44mm
  • put a text box inside it, and also
  • put some 9mm holes inside the rectangle.
But I have absolutely no idea how to achieve this!  Smiley Sad
Thanks for your help.
Andrew
22 REPLIES 22
Message 21 of 23
in reply to: j.palmeL29YX
Sorry, cadder, I can't see how to attach a file (eg. the .dxf file produced by Visio) to my post?
Also, I notice you have included some of my last post in your answer.  Whereas I can just see how to 'Reply'?
Other Fora offer a choice of:
  1. 'Reply' - iow, just write your text, as an independent reply, and
  2. 'Quote' - write your text directly in response to a previous reply.
But I can't see how to do #2, here?
Andy
Message 22 of 23
j.palmeL29YX
See this screencast: https://autode.sk/2n464cB
To attach a file, scroll down, then ...
OK? Have you seen how I did it?
And you have also seen how to include the content of a posting.
If you want to add another cit, repeat this:
Now you can answer to second cit.
And if you want to cit from another post, do it again ...
@Anonymous  schrieb:
and copy and paste the text from another posting here.
HTH
cadder
Jürgen Palme
Message 23 of 23
Kent1Cooper
@Anonymous wrote:
.... I can't see how to attach a file (eg. the .dxf file produced by Visio) to my post?
.... you have included some of my last post in your answer.  Whereas I can just see how to 'Reply'?
To attach a file, look below the Screencast box:
To quote, you pick Reply and then you have the option to include quoting in the upper right:
Kent Cooper, AIA
Technology Administrators
