AutoCAD Forum
How to change xref file name without open drawings.?
11 REPLIES 11
Message 1 of 12
mohamedahsaan126
5977 Views, 11 Replies
Dear All,
I have lots of drawings with 8 xref file.
Now unfortunately i have to rename some xref files.
If i changed name, must change path with the new name.
Is there any option to do quickly, without opening each drawings.?
Sample:
BEFORE
Folder_1\map
Folder_2\map
NOW
Folder_1\map          ................This one OK
Folder_1\map_2       .................This one making problems
Thanks in Advance
Labels (1)
11 REPLIES 11
Message 2 of 12
vinodkl
in reply to: mohamedahsaan126
First rename the xref files and then use the reference manager to change the path of the xref. The Reference manager can be accessed by click on the windows key and then expand the AutoCAD version and then click on the Reference manager.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 12
Yes you can do that by Reference manager , you can get more information Here
Imad Habash
Message 4 of 12
Thank you guys,
I have tried Referencing Manger. it's only for changing the path with the same name.
There are no option to change the xref name.
Message 5 of 12
pendean
Reread the first reply you got and it's first sentence on how to start the process https://forums.autodesk.com/t5/autocad-forum/how-to-change-xref-file-name-without-open-drawings/m-p/...
Message 6 of 12
mohamedahsaan126
in reply to: pendean
Thank you for your effort.
I have tried again. same result.
Reference Manager is asking only the path of Xref (..\Folder Name) ,Not asking Xref files name(..\folder_1\Map1).
May be i am going wrong way. Please guide me.
Message 7 of 12
Hi @mohamedahsaan126,
It sounds like you need to change the file name of existing Xrefs in your drawing and are trying to update the reference with the new name without having to open each drawing.
The reference manager is able to update a reference to a new path, or new drawing as long as the file name is the same as the existing reference. I have not found an option for updating an existing reference with a new name outside the Xref manager in the drawing itself.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 8 of 12
pendean
Message 9 of 12
mohamedahsaan126
Thank you dear @cheryl.buck  You got my point. Actually it was very nice explanation  of my problem very clearly.
I have a big problem with language, I'm really sorry for that.
And Thank you Mr. @pendean
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/xref-lisp-rename/td-p/6401212
https://www.cadtutor.net/forum/topic/33669-changing-quotreference-namequot-to-match-xref-file-name/
https://jtbworld.com/autocad-xrefrename-lsp
here i couldn't find any link for LISP file, I don't understand that code also.
Please can you guide me.
Message 10 of 12
You are quite welcome, you did great!
It may be helpful to post in the AutoCAD Customizations forums. The members there are more familiar with LISP and other scripts.
I hope you are able to find a custom solution quickly!
All the best,
Cheryl Buck
Cheryl Buck
Message 11 of 12
Thank you so much for all,
But unfortunately i have complete that work manually 😃. I'll try here AutoCAD Customizations .
Message 12 of 12
Forma Design Contest
