hi, when using a dimension line horizontally it also puts the text horizontal. but because that takes up to much space we like to put it vertically (go to properties > text > text rotation > and set it as 90 degrees) but this takes so much time when working with 100+ dim lines. is there a way to get a macro to change the properties. or some other way to automatically change the text rotation of a dim line? ill attach a picture of the problem! thanks in advance!
edit: the problem only occurs when draggig the text. when dragged it automaticly changes to its horizontal positsion.
Solved by j.palmeL29YX. Go to Solution.
Dimension styles does not have a text rotation option.
Here are a few ways to do a mass dimension text rotation.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Try this LISP (quick and dirty) :
(defun c:DTV (/ pi-2 ss number ent edat)
;;; DimText vertical
(setq pi-2 (/ Pi 2))
(princ "\nSelect Dimensions: ")
(setq ss (ssget))
(setq number (sslength ss))
(repeat number
(setq number (1- number))
(setq ent (ssname ss number))
(setq edat (entget ent))
(setq edat (subst (cons 53 pi-2) (assoc 53 edat) edat))
(entmod edat)
HTH
Jürgen Palme
(setq ss (ssget))
(repeat number
(entmod edat)
HTH
Jürgen Palme
